steveo3002
anyone found a gravity mini gun but with a large nozzle - been spraying a few bits n bobs for under the car and would prefer something that hoofs the paint out thick
I am sure this is the one I have https://www.machinemart.co.uk/p/pgf18-gravity-fed-pro-spray-gun/ but I don't see mention of LVLP in the page.yeah 1.8-2.0 or so ,but in mini gun size
It is quite small, only got a 600mm cup, you can get the fan down to a couple of inches on mine, I certainly would not want to spray a full car with it, would be very slow going. I will get a shot of mine with a mug for scale.isnt that just a normal size gun though?
No worries, here is a pic anyway.yeah sounds like a standard one...i want the smaller one
No, I can not see how you would hone the tip and needle to match.do you think roaring the tip out from 1mm to 1.2mm would work?
I had one with a 1.2mm tip and have been looking for another for ages. They are good for primer.
The only one I've seen since is a devilbiss sri pro but they are about £100 and way too good for primer.
much handier for me for small brackets and stuff like a single wheel , less mess to clean up as its a smaller pot , perfect for my needs but if i could get a bigger set up that would be even better
plus they're like £10-15 so who cares if it gets ran over or whatever
I still can not see it, the Fastmover mini gun looks just the same as my gun only with a .8mm cap / needle and a 125mm pot.I like using a mini gun for small parts as it less of the paint goes to waste.
