Hi all not been in here for ages
I have a problem with the above welder the wire feed is not working and I cant find the fuses for it, anyone got any ideas where they maybe
Thanks David
To the best of my knowledge there are no fuses for the feeder motor. The motor is a 24VDC compound type motor with the main stator field fed via a huge cheramic resistor placed at the top left corner of the controller PCB. The motor armature is fed by the power transistors (2N3055) in upper right corner of PCB and on the back side of control box. Check these for faults.
