123hotchef
- Kent
Tell me wise ones.
For welding stainless do I need to use a different liner in the mig gun?
That is good enough for me, thanks.I’ve always used the regular ms one,though I do blow it clean with the airline.
I could possibly spring for a dedicated stainless torch
I have the dedicated weder already! well kind of its the new to me jassicSeeing as you have to take the wire out anyway swapping the torch is quicker than swapping the liner and then you can leave dedicated end consumables fitted.
Plus you can fit that torch onto the dedicated welder you buy when you get fed up of changing wire/torch/gas/machine settings
Just swap the liner out then.I have the dedicated weder already! well kind of its the new to me jassic
0.8mm I may flip between steel and stainless if I need to use the machine away from home.Just swap the liner out then.
What size wire are you using? I've got a box of Liners that might have a stainless one in..
