davidjohnperry
a different breed
- yate/bristol
SWP MIG 220 Welder
•220 Amps 230v Single Phase
•Professional Line - Manufactured in Europe
•2 Year Comprehensive Warranty
•Next Day Delivery*
£ 590 (inc VAT)
Shipping £6.95
(inc VAT to UK Mainland exc Highlands for any number of items)
*UK Mainland, subject to stock availability
SWP MIG 220 Welder
£590 (inc VAT)
Quantity
0.6mm/0.8mm Wire Feed Roller
£16.85 (inc VAT)
(0.8mm/1.0mm supplied with machine)
Quantity
5kg MIG Wire Spool Adaptor Kit
£16.25 (inc VAT)
For fitting 5kg wire spools
Quantity
Specialised Welding Products Professional Line (orange casework) of European built MIGs have a proven track record for reliability and excellent weld performance throughout their voltage range, with a lovely smooth arc condition; weld from the thinnest materials like car bodywork up to more demanding tasks such as wrought iron work etc.
The 220 model is ideal for professional garage workshops, maintenance & light fabrication jobs, heavier home workshop use etc.
Features include:
•Quality wire feed assembly - All metal, geared wire feed with a good sized motor for positive wire feeding and uniform welds.
• Soft-Arc technology - Quad plate rectifier & smoothing capacitor bank give a lovely, smooth arc condition. Welds from just 15.5 Volts so performs brilliantly on very thin sheet metal.
• 12 Voltage settings for fine power control with a large, heavy duty selector switch fitted as standard.
• Fully copper wound transformer & choke with twin-fan cooling system and 3 year warranty cover
• Electronic spot-weld timer for consistent, repeat spot/plug weld results
• Heavy duty (and we mean heavy!) rear wheels & front castors so the machine can be manoeuvred easily across uneven floors.
Supplied with:
• 3 Metre MB25 Type Euro-Torch Assembly
• Twin Gauge Industrial Argon Gas Regulator
• 3 Metre quick-connect Earth Lead Assembly
• Comprehensive 2 Year Warranty Cover
• 3 Year Main Transformer/Choke Warranty
SWP MIG 220 Welder
Technical Specification:
• Amps Range: 30A/15.5V – 220A/25.0V
•Supply Voltage: 230V Single Phase
•Input Fuse: 25A @ Maximum 220 Amps (13/16A on lower ranges)
•Duty Cycle @ 20%: 190 Amps
•Duty Cycle @ 60%: 100 Amps
• Duty Cycle @ 100%: 70 Amps
•Voltage Steps: 12
•Weldable Wire Sizes: 0.6mm – 1.2mm
•Wire Spool Sizes: 5kg (requires adaptor) - 15kg
•Weight: 60kg
•Dimensions: 830mmH x 302mmW x 780mmL
•Protection: IP23S
from weld equip
BritArc 241
Part No.BA241
Our Price:
£750.00 inc VAT
£625.00 ex VAT
uct Description
Specification
This brand-new machine is the result of a collaboration between the technical knowledge and manufacturing capabilities of Tec-Arc and Wellington Welding's own practical welding expertise. The result is a 240Amp Mig welder that is aimed at general welding and fabricating applications from 0.6mm through to 12mm welding thicknesses. This is for the welding shop which needs a machine that is versatile as well as reliable.
Consistent with a power output delivery from 20 to 240 Amps, the BritArc 241 has heavy duty smoothing capacitors fitted, which ensure spatter is kept to an absolute minimum even at higher welding currents. This is not something that every manufacturer will do since it adds cost to the product and is not visible to the would-be-buyer. However once you start welding with a machine with capacitors fitted you will notice the smooth arc and if you get back to a machine without capacitors you will detect a noticeable harshness and coarseness in the welding arc .
The BritArc machines are manufactured in Great Britain to industrial standards. They are constructed using heavy gauge, powder-coated steel and high quality internal components - ensuring that they will withstand the most demanding of environments. These machines are probably the most reliable compact Migs available, with thousands already in use in the UK.
An example of all this care and attention-to-detail is in the Swedish-made wire feed motor. This component ensures a smooth, reliable and accurate wire feed, which is critical to a stable welding arc. The BritArc 241 also has an industrial quality euro connector and we include an excellent MB25 type 3m Mig torch as well. This has spring supports in the critical areas behind the handle and in front of the torch connection with a rotating ball joint where the welding lead connects to the torch handle. Other Mig machines will offer a cheap, hard-wired Mig torch; this is not a good solution. Our recommendation is to always choose a euro connect torch. You will love it.
All BritArc Mig welders are capable of taking a full size 15Kg reel as well as the smaller 5Kg reel.
Power is controlled via a 12 position voltage switch and infinitely adjustable wire feed speed, which is synchronised to output and ensures perfect arc conditions across all settings and material thicknesses from 0.6 to 12mm. Also included is a built in electronic burn back which is optimised for all the settings. Warranty is 12 months with 5 years on the main transformer. Wellington Welding guarantees to fully support these machines with spares & service for a minimum of 15 years.
Package includes:
BA241 Compact Mig Welder
Undercarriage & Cylinder Tray
2m Earth Lead & Clamp
Gas hose & Fitting
MB25 3m Type Mig torch
2 Contact Tips
im looking for something for light to med fabrication 5-8 mm
•Next Day Delivery*
£ 590 (inc VAT)
Shipping £6.95
SWP MIG 220 Welder
£590 (inc VAT)
Quantity
£16.85 (inc VAT)
Quantity
£16.25 (inc VAT)
Quantity
Features include:
Supplied with:
SWP MIG 220 Welder
•Voltage Steps: 12
•Weight: 60kg
•Protection: IP23S
from weld equip
BritArc 241
Part No.BA241
Our Price:
£750.00 inc VAT
£625.00 ex VAT
uct Description
Specification
Package includes:
Gas hose & Fitting
2 Contact Tips
