ajlelectronics
- Gloucester, England
Quite clearly, this is down to me, not the machine, so would appreciate some tips please.
Welding today on the Scorpio 1mm and 2mm steel, weld through primer coated. Gas is Argon mix, flow set with a pea shooter at between 12 and 15 lpm for being outside the workshop. Bottle regulator showing pressure of 75 Bar so not low gas I believe.
The welding was almost silent, with none of the normal sizzle noise. Weld was high in profile although it appeared to penetrate OK. Once in a while it started to spit and sizzle. Was this in "spray" mode or what?
