Looking to buy welder for small project
  1. steve1971 Member
    16
    bolton
    Hi.
    I bought a trailer for 20 quid that needs some restoration for use as a camping trailer and add some bits , It looks to have been a builders trailer going of thickness of the section,
    Its been left stood for years the inch ply on floor has gone and so has end of one of struts so I'm thinking this could be a good project to learn to weld with a view to doing any welding i may need in future
    I will be doing all welding outside at side of house so the welder needs run off a 13 amp socket,
    i'm on a very limited budget welder wise and have been told by someone stick welding is the way to go any help appreciated as i don't know anything about welding really,
  2. daleyd
    daleyd Member
    5,041
    Wrexham, North Wales
    Not wanting to rain on your bonfire but is a rotten trailer the best project to learn welding on?
    The potential for something to go wrong should it fail is quite high. I'd suggest getting some clean metal and knocking up as many test pieces and/ or small projects (shelves, boot rack that sort of thing) first until you are confident in your ability.
    If your not wanting to weld car bodywork type material (thin) then a stick welder should suffice, and be a chunk cheaper than a mig. See weldequip shop above for an idea of prices.
    arther dailey, Badger1bear and skotl like this.
  3. W.olly
    W.olly Member
    1,627
    Radcliffe, Manchester
    i started with a stick welder buzz box type. Pick them up cheap less than £30 and easy to learn. Just give lots of practice and show a few pics on here to get feed back on it.
    Similar to daleyd says really. If you are welding it up make sure you are good and they are good solid welds,
    daleyd likes this.
  4. Arclikeharrypotter Member
    814
    Northampton
    As Daleyd has said it's not the best of projects to jump straight onto, but with alot of patience and practise it's not impossible. But be under no illusion that on a trailer you are going to be using on the roads there is no that'll do, you either put down a good weld or its no good. You may also find that if the rust is extensive you almost end up making a whole new trailer!
    daleyd likes this.
  5. steve1971 Member
    16
    bolton
    Thanks for the replies, I'm not saying I'd buy a welder and first join I did would be on the trailer, it's only that one part that rotten due to how was stored rest just surface rust on the A frame and the frame for the ply
    I was thinking worst case new piece of box Section to replace right across or plate it over
    My father in law is a retired welder and used weld bridges, roller costers etc so think he could check over the welds for me
    He don't really have knowledge of small welders all stuff they used was on large size
    So I thought I'd ask here about a cheap stick welder
    daleyd likes this.
  6. Arclikeharrypotter Member
    814
    Northampton
    Like you said you'll probably want to replace the whole section of box, plating over it would more than likely cause more problems in the long run. As for your father in law big or small you can either weld or you can't! So you'll probably find him a wealth of knowledge.
    What sort of budget are you thinking?
  7. norlander
    norlander Member
    3,390
    Europe, mocycling paradise
    As ever, apart from buying the welder, do you have angle grinders gloves etc.? if not budget for them (needn't be that pricey, cheepy Chinese around 10 quid to start off with).
    Inverter set if you can run to it could help as they usually have anti stick etc which is handy for a beginner, but nowt wrong with the good ole buzzboxes.
    Decent auto lid very useful, again some reasonable priced ones for stick if you don't need shades for TIG.
    The thing about an owd trailer is- you have a "hard drawing" /template and possibly a jig if you want to make a complete new one.
    Happy renovating.
  8. steve1971 Member
    16
    bolton
  9. steve1971 Member
    16
    bolton
    Daft question but I have a 3kva 110 tranny could I run a welder off that give me more options on welders
  10. winchman Member
    2,225
    Merseyside
    Try Gumtree, Ebay etc, personally I would buy an Oxford oil cooled (Or any oil cooled) one as they are cheap (50-100), 10 times better than a Buzz box, but very heavy. but a £30-50 Buzz box would get you started.
    Buzz box on Gumtree in Manchester for £30?
    Grinders are about £15 in Screwfix, mask £20 from Ebay, gloves again Ebay, so you should be able to get up and running for under £100 possibly a lot less.
  11. winchman Member
    2,225
    Merseyside
  12. winchman Member
    2,225
    Merseyside
  13. steve1971 Member
    16
    bolton
    HI,
    Pdg I just thought I seen people running welders off 110
    Winchman shame its least couple hours round trip away I doubt he would keep it till I had free time get it,
    Would it run off a 13amp socket
    My only thing is seeing I never used a welder how would I know it's safe can much go wrong with them
    But now you linked that I'll deff look at second hand
  14. winchman Member
    2,225
    Merseyside
    Take a mask and ask them to show working, You could offer to pay now via Paypal etc and collect in two weeks, might be worth asking?
  15. steve1971 Member
    16
    bolton
    Didnt see second one it's nearer to me
  16. steve1971 Member
    16
    bolton
    What thicknesses would it weld do you happen. Know I'll try look it up
  17. winchman Member
    2,225
    Merseyside
    I suspect it will weld over 3mm and bigger than a domestic 13A plug can handle, but plug it in and stick to small stuff it should be fine use a 13A fuse in the plug and a good quality MK plug and wall socket straight from the ring main, you could in future do bigger but I suspect you would have to wire a dedicated industrial type plug straight from the fuse board.
    Its better than what you need but at £60 a bargain
  18. steve1971 Member
    16
    bolton
    Dunno why but I'm drawn more to the Oxford ☺️
  19. steve1971 Member
    16
    bolton
    Ah thanks for that on tranny just a idea and it's been sat doing Nowt for ages
  20. winchman Member
    2,225
    Merseyside
    I too have an oxford, I was given it for free as it didn't work took 10mins to fix and cost nothing, I feel they are the Rolls Royce of welders but not exactly portable!
Advertisements
