angellonewolf
- bristol england
can this be done i have accuired some 5mm plate painted will have to clean it off for welding its a little more thickness than i need but its free so worth doing the work but the frame for my welding trolley is only 2.2 mm and im using setting 2 and max switch being only 160 amp ish could this weld the 5mm to the 2.2 with out blowing through and weld it properly ?
