if its that thin can u back it up with anything .steel aluminium or anything so it acts as a heat sinkcan anyone give me a rough idear weather ill be able to arc weld a fairly rusty mower deck useing 1.6mm rods i want to get on with rebuilding it an im fed up with the mig not working
what do you mean by that ? id say its about 1.2 at its thinest but its a bit hard to tell ! i just really want to tack a patch over the 2 big holes to stop anything flying out its not structual :if the metal is quite thin chances are u will burn through. if u can backup the base with a heat sink eg scrap metal aluminium . copper even steel clamped to the rear . lay patch over the hole and weld. it wont burn through because of the mass of metal behind will keep it cool . then remove when completed
