Just found you after my welder has failed. Now stuck with a van jacked up and no welder!
Have a Thermal Arc Fabricator 211i, is it worth fixing? Can it be fixed? The power is not consistent, start a weld then 2 seconds later power dies.
Cheers
Hi guys so I see that this might be a common problem. Mid weld today my trusty 211i just went blank. No illumination on the faceplate and the fan would not run. I opened up the welder to take a look and it seems to be quite dusty I should imagine this is the cause. I'm not going to try and...
www.mig-welding.co.uk
It includes troubleshooting info and a block-level circuit diagram.
