FergalFarty
- Bristol
I've got some 20x40x2mm stainless box section which I've welded with mitred corner joints. The joints are a good fit, but when I grind off the welds, the metal has shrunk a bit leaving an indentation across the face of the joint. I'd like the face of the corner to be nice and flat so that I can sand it like in this video:
Do I add filler to fill in the dent so that it's proud of the surface and then grind it back, or will that make things worse?
Thanks
Fergal
Thanks
Fergal
