I'm still looking at the options for an ARC/TIG Inverter (incidentally Weldequip did you not get my PM?). The Invertor Fusion 200 seems to cover all bases, plus some, but it states it needs 22 amp fuse. So my question is:
1) Can it be run of a spur to a normal household ring circuit? So in a workshop enviroment I can use the full range.
2) What sort of plug/socket would you normally use on such a machine
3) Can I run it off an extension lead/generator but accept that I may not be able to use the high end when working outside?
Thanks
Thanks
