Four Post Lift
  1. reb78 Member
    277
    Herts UK
    I'm in a position where I can accommodate a four post lift for working on the cars. These will be Land Rovers at the heaviest. I think I would prefer a four post over a two post that leaves the wheels dangling. I'm thinking second hand to save on cost. The shed that it will go in has single and three phase installed.
    I don't really know anything about them though. What do I need to look out for? Are there makes to avoid? Are there sources of these that folks know about other than ebay?
  2. Bobtail4x4 Member
    471
    yorkshire
    a 2 post means you can work on the brakes, or when changing the wheelbearings again. and again.......... landrover owner here too,
    slim_boy_fat likes this.
  3. gordon stephenson
    gordon stephenson Forum Supporter
    5,790
    Skelton in Cleveland U.K.
    My son has a 4 post lift that also has two parallel rails so that you can lift the body only when up to a comfortable working height leaving the wheels freee, It is quite an old model but works very well.
  4. johnik
    johnik Member
    308
    sunny Somerset
    Best to get an old bradbury or similar,they were designed to last for thousands of years, wheel free,s are a must. about the only thing you cant do on a 4 is a front wheel drive transmission out:whistle:
  5. zzr1200
    zzr1200 Working at 650 ft on open steel work
    3,037
    Chesterfield, Derbyshire
  6. gaz1
    gaz1 Member
    5,284
    westyorkshire
  7. R-D-R Forum Supporter
    299
    Derbyshire - England
    If its RRS an D3/4 your working on a two post makes body off procedures possible/easier
  8. 8ob
    8ob Member
    1,976
    moscow on thames
    I miss my 4 post wheels free, it had lights , plug sockets and air plumbed into the middle of the ramp which was really useful, when a motor is on the wheels free bars the platform makes a much needed table for parts and tools. Can't think of one advantage the two post has over an old wheels free four poster. They don't need to be dismantled either, if you raise the platform, back a trailer underneath it, pull the safety bars out of the top of the columns , lower the lift onto the trailer, unbolt the legs and disconnect the urlecktricks , lay the legs on top of the lift, job done.
    bob
  9. keithski122 Member
    652
    uk
    I used to be a mechanic and would much prefer a two post lift to a four post lift.Mind you I worked mainly on cars.One advantage is doing a front wheel drive gearbox removal.
  10. Wedg1e
    Wedg1e They call me Mr. Bodge-angles
    5,878
    Teesside, England
    I know a guy in Lincs who bought a 4-poster for his garage. It was too tall and too wide for the building so he had the frame cut in half and the posts shortened and rewelded, only now the cables were too long. Luckily, as it turned out, because when he tried flexing them, strands started snapping - and it had a recent test certificate!
    Then he had to replace all the safety nuts and then change the 3-phase hydraulic pump for a single-phase... by the time he'd finished he could have commissioned Bradbury to make him a new one!
  11. armalites Member
    2,637
    Herefordshire
    I've got an old Laycock HSL Wide that came out of Post Office workshop. I've got 2 jacking beams so can get all 4 wheels clear. I paid £300 for it at auction, I had to buy and inverter.
    If you like tinkering with cars a ramp is a dream come true. I never forget the day I lifted the first car on mine, it was 0200 am and I'd spent the evening setting it up after work.
    2 post lifts are good for servicing but if you you are working on rotten old rusty stuff then I think a 4 post is better. They are also more stable. In an ideal world I'd have both.
    You do have to be careful as some of these lifts could be 30+ years old and maybe you can't get spares.
  12. 8ob
    8ob Member
    1,976
    moscow on thames
    A guy I know had his four poster outside, he built a frame with a clear sheet roof over it that was fixed to the platform . When the car went up the roof went with it. looked odd when it was up but just looked like a car port when down.
    Bob
    rtcosic likes this.
  13. Stueeee
    Stueeee Old git
    230
    N W Kent
    I have a four post lift in one of my garages. After years of scrabbling around working under cars on axle stands; it still feels like a real luxury years after I installed it. It's not a "wheels free" style, but I have two jacking beams fitted to mine, so it's possible to lift the front and rear wheels clear of the ramps.
    We did remove the ramp without dismantling it; speed was of the essence as the seller's garage had ceased trading. Definitely worth taking it to bits if you can IMO, they're really awkward things to transport in one piece even with a HIAB lorry. Also, unless you have almost infinite height and width where you're going to install it, you'll need to dismantle the lift to install it, as I did.
    So, as delivered, my temporary garden ornament:
    [​IMG]
    This was a 4 ton lift wide enough to take a twin rear wheel van etc. I narrowed it a bit as otherwise my pre war Austin Sevens would have fallen through the centre gap. As noted earlier in the thread, this means that the lifting cables are not the correct lengths anymore. It was about £150 (IIRC) to get a new set made up -it's worth changing a set of unknown cables on a secondhand lift anyway IMO-
    here's re-assembling the lift in my new garage.
    [​IMG]
    First lift, before I installed the jacking beams or sorted permanent power and air line connections.
    [​IMG]
    indy4x, wookie, 8ob and 2 others like this.
  14. rtcosic
    rtcosic Member
    Why didn't I think of that!
    I built my house in 1989 leaving just such a space at the side. All the years I've wasted crawling on the garage floor under axle stands!
    Can you imagine the neighbours' reaction when your 'permitted development car port' appears above their 6' fence?
    [​IMG]
    indy4x, dobbslc and GW8IZR like this.
  15. armalites Member
    2,637
    Herefordshire
    Can someone ban this member, nobody wants to see pictures of other peoples workshops when they look like this! :laughing:
    Asolutely stunning space, the beam hoist is super cool. Looks like it may be able to go to the centre of the car so you could pull and engine?
    My ramp sits in an open barn, hopefully one day it will be in a new shed.
    wookie and johnik like this.
  16. GW8IZR
    GW8IZR Gone.
    2,371
    Anglesey
    Thats a fantastic image - it would be fun to put the BBQ on it and ride up there to look at the mountains :-)
  17. rcx132
    rcx132 Philip
    1,650
    London, UK
    Just a heads up, with the cheap eBay lifts, if you look at those, there's a statement on the HSE website saying that a lot of them carry fake CE markings and there have been serious accidents.
    johnik likes this.
  18. wookie
    wookie Can't I have an easy job for once ?
    2,026
    Usually under a car in my garage that's halfway up a Welsh mountain
  19. zzr1200
    3,037
    That's why the best buy is a Bradbury Lift and spend a bit of money on it.
  20. zzr1200
    3,037
Advertisements
