I'm after some advice as a newcomer to Mig welding, been doing my research and understand for welding car steel panel its a lot about the Low amps and the speed of wire so questions are if you please-
looking at a Wolf 140X 30-135 amp range or a Draper 16057 21-100amp range?
wire i need advice on, do you use different thicknesses if using Gas or Classless?
am i right to use 0.23" or 0.6mm for 0.8-1mm steel on cars using gassless?
what speed should i use?
Thanks in advance
Thanks in advance
