Hi,
I've been doing a bit off bodywork on a car, welding in new patch panels and grinding back some surface corrosion. I've now finished the welding stage but I'm not sure where to start with the painting side. I've got the below products, just not sure what order I should use them.
Brushable seam sealer
hammerite rust remover gel
Screwfix no nonsense zinc galv aerosols
Tetrosyl 1k etch primer aerosol
4l jotamastic 87 with WG hardener
hammerite metal paint tin
Need to buy some stone chip and considering using Tractol enamel paint. All the bodywork is generally hidden in the wheel arch, inner arch and chassis rail. Have access to a good compressor but not sure its worth the hassle with H&S and masking stuff, any thoughts?
I've got pictures but photobucket isn't playing ball atm.
