Hello everyone,I trust you are all well.....I intend to do a bit of ally welding using 1.2mm wire,using my draper 70047 welder. I suspect it is an MB15 torch and was hoping that,there are 1.2mm tips for this torch....your advise most appreciated
Should be easy to find then.
You just want a 1.2mmA tip (which is actually bigger than a 1.2mm hole) or a 1.4mm normal tip which you might struggle to find in m6.
You might want to check your welder has got the guts to run 1.2mm and that you can get the aluminium rollers in that size first.
You'll want a teflon liner for the torch as well which might be tricky if it's not a mb25/euro fitting
