Wheely
New Member
- Accra- Ghana
Hi All,
I am looking at applying a good insulating material for Wheely (1995 Land Rover Defender 6x4) so that in my trips around Ghana and Africa I won't suffer too much from the engine heat nor the very loud engine noise
I bought 20mm Kaiflex https://uro-camper.com/tiendaonline...miento-termico-kaiflex-autoadhesivo-20mm.html (in spanish but you can ask google to translate the page)
I plan to cover it all top to bottom (all floors and the ceiling) - I removed the headlining and the original carpet as it was in horrible conditions.
I have a series of questions, but the most relevant for this forum are:
1) How do you recommend to treat the surface on which the material will go? Currently it’s bare metal ( a bit rusty). By this I mean, besides cleaning properly, do I need to paint with a special material (e.g. rust converter, waxoyl, …)
2) Since it will be applied where there were seats that are now removed and there are holes exposing it to the bottom of the vehicle/road, what should be done to cover the holes before applying the kaiflex on top
3) I've heard the moisture we produce while sleeping condenses on the steel panels, gets trapped in the insulation and causes rust. Between the steel panels and the insulating material do I need to put anything to prevent moist to get trapped and cause rust? Do I need to give a special treatment to the steel panels like they do here https://www.sounddeadenershowdown.com/camper-van-conversions
Thanks so ever much,
Simone
Simone
