On occasions upon releasing the trigger, the wire bunches up as if the tension is to heavy on the wire prior to entering the lead. I'm aware that the tension should allow the wire to slip when releasing the trigger, but all attempts have been futile to correct the issue. I'm curious if it could be the feed rollers causing the issue? Any suggestions would be appreciated.
