Andy Smith
New Member
- Hull
Has snyone used a clarke 151 te on household 13 amp plug before and whst amp is ok to weld at
Ok thanks for extra information but hear of people saying it needs upgrade on clamp lead and power lead i already have a gass bottle and regulator ready with hose connector.the earth lead should come with the welder if not you need a clamp style earth clamp some use the extra copper inside of them for better connection to the metal others use a bolt type of clamp for there earth connection
welding at full power can be done but you learn your limits of the welder allowing it to cool down at certain points before it trips out other than that it will weld up too 5mm with prep as ive done it at that rate and can go low enough to 0.8mm if you learn the patient route
other than that a good welder better than some welders out there and does hold its price rather well if not on here though but saying that many members have had this type of welder and manage with it over the years before upgrading there system to another model or system
