C chanyboi New Member Messages 3 Nov 9, 2009 #1 ive got an 'A' under the 1 power setting on the welder, what does it do? p.s. i only bought the welder today
Porschemaniac Member Messages 305 Nov 10, 2009 #2 After looking at the manual I assume this is a power setting. The Power Setting Tables (beginning on page 26) refer to a combination of setting - A 1, B 1 etc. You will find that the power is set, using a combination of the two switches on the front - A / B for coarse adjustment and 1 / 2 for fine. The full range of power setting would run A 1, A 2, B 1, B 2 - so the two switches give you four individual power settings. Hope that's helpful. Regards, Ian.
C chanyboi New Member Messages 3 Nov 12, 2009 #3 dont quite understand. 1st switch has '1' above an 'A' 2nd switch has '2' above an '3' 3rd switch has 'min' above an 'max'
shenion Tool Pack Rat Messages 7,586 Location Stone Mountain, GA USA Nov 12, 2009 #4 Switch 1/A is '1' or on 'A' it is whatever the 2/3 switch is set to. Saves them needing a 3-position switch.
Porschemaniac Member Messages 305 Nov 12, 2009 #5 Oops, think I was looking at the wrong welder in the manual Check out page 28 in the online manual - here. Gives you the full range of combinations for the switches. Hope that helps.
B Barkychoc Member Messages 45 Nov 14, 2009 #6 Some of the Clarke manuals have the power settings incorrect in the manual. I have a 160EN and the settings in order are 1 MIN 1 MAX 2 MIN 2 MAX 3 MIN 3 MAX which is not what it says in the manual!
