The wire feed has failed, the motor makes a noise when the trigger is pressed, then just stops. Even with the wire completely removed the feed drum doesn't move. Any Ideas?
I powered the motor from a car battery, motor is fine. Multimeter indicates no voltage across motor terminals when trigger is pulled. There is an arc in relay when trigger is pulled, relay components moves.
