Richard.
- Cambridgeshire
So short 2 and 3 yes?TIG 168
1- Switch GND
2- Cold current button
3- Welding torch button
1- Switch GND
I have a click when I press button.Stinger + "work return" wired up.
I have sparks!
Do you have a buzzzzzz come in about a second after the click.I have a click when I press button.
I don't have a hose clip to fasten gas hose onto the connector...
Is that the little rectus 20ka on the front.I have a click when I press button.
Yes.?Is that the little rectus 20ka on the front.
Your good mate. I know what you paid for that too. Absolutely spot on. It looks like a new machine. Put a pic of the offending connection up I’ve probably got something that fits. I’ll send first class tomorrow if I do.Yes.?
The front works fine.
It's the rear connection from the hose to the machine.
I have the hose + regulator, but the hose is 3/8" both ends, and the machine is 1/4".
Should have got an adaptor, but didn't.
I have a spark from the torch when I press the button and there's definitely a change when I alter the power dial.
I *think* I'm good.
Thanks for the offer, but I'm good - taking exmrsegg shopping in an hour, so I'll nip into local diy shop and get a hose clamp.Your good mate. I know what you paid for that too. Absolutely spot on. It looks like a new machine. Put a pic of the offending connection up I’ve probably got something that fits. I’ll send first class tomorrow if I do.
Never. Don't use PTFE on bullnose fittings it won't help as the seal on on the nose, the thread just holds it against it.Tiny bit of a leak between the bottle, and regulator.
Bit of PTFE tape?
