You need one of these tyres -
Hateful things. Allroad has one. Good luck blowing it up, when new they work when you need them no chance
Repair cords , plugs and cans of foam are brilliant unless you get a cut in the tyre. Unfortunately for me every puncture I seem to get on the lanes in an instant flat cut type that there isn’t any patching it’s a swap the wheel or drive on the rim job, Most permanent 4wd systems will cope with a space saver even audi’s Torsten system the speed limit on space savers is probaly more to do with keeping the spider gears in The diff happy. Or possibly tyre temp than grip. Space savers grip I tryed auto testing with space savers on the back hopeing for less grip that didn’t work they hung on way to well. Mismatched tyre sizes with a torque biasing diff you can get away with if needs must twitches a bit probaly dosent do the diff much good. With a plate diff bad idea diff dose not like it nor will you , even in ******* down rain you end up stopping and swapping the space saver or spare wheel onto the rear or in my case I had to put both rears on the frount and the one frount tyre and space saver on the rear probaly because the golfs diff is set very tight ( really way to tight for a road car ) people look at you funny when parking it clacks that much , sounds like you’ve bust a cv
Go to get the wheel off & its welded to the hub.
