Yes, replaced the wheel bearings on the Spec B and may have also changed the drivers side on the Outback, can't remember for sure.Yep same 6 speed casing but with Hawkeye sti gear ratios just with a longer final drive,
The wheel bearings are bolt on items, nice and easy to change.
Yes still have it, it is minus a passenger seat though as that is now my computer chairHappily buy most spec b''s we can get hold of if cheap money! Especially if manual. Do you still have it??
They do have a little whine due to the step off gear but shouldn't be "noticable" as such.
Well see if the problem manifests itself on the drive downNot far from you, probably only 500 miles or so
Spec B with outback behind. Outback was the wifes so was clean, Spec B was mine so never washed. I now have the outback so it is the same state as the Spec B was
Ok will have to check that out, maybe no oil in itYes, duff runs 75w90 and gearbox runs atf
