Buying pneumatic wheels which aren't garbage
  1. thinfourth pleb
    792
    Stonehaven
    I am wanting to make a wheel barrow like device.
    To do this i will need to buy some small pneumatic wheels.
    Where can i get ones at reasonable cost which aren't chinese garbage which after 12 months has the air holing abilities of a sock?
  2. MCKDAVID Member
    probably with difficulty, even if you pay a decent price, probably made over there anyway.
    Depending on the size and diameter, what about scooter front wheels. The tyres are rated for the road so should be decent enough.
  3. addjunkie
    addjunkie Forum Supporter
    2,914
    Northumberland. Reet oot in the sticks
  4. dobbslc
    dobbslc Member
    2,603
    Hertfordshire UK
    I've seen some on wheel barrows that are yellow and made from a kind of high density foam, they can't be punctured.
  5. thinfourth pleb
    792
    Stonehaven
    It's not punctures which is the issue
    It is the fact that the rubber they are made of lasts 18 months and then falls to bits
    If the for ones last the same amount of time then it is a waste of money
  6. pedrobedro
    pedrobedro Man at Matalan
    8,455
    CX Derbyshire
    Get some barrow wheels and put 8" trailer tyres on when the originals perish. If you leave them in daylight they will crack in no time, cover them up when not in use.
    Robotstar5 likes this.
  7. 8ob
    8ob Member
    1,476
    moscow on thames
    I had the cheap chinese pretend rubber wheels/tyres on my yard toolbox, no end of grief with flats so I changed them for solid. Has been alright but they develop small flat spots when they sit for a while so best to move them about a bit.
    Bob
    [​IMG]
    [​IMG]
    Maker likes this.
  8. brightspark
    brightspark Member
    21,854
    yarm teeside
    what u want are a set of a motobility scooter pukka quality
    eLuSiVeMiTe and 8ob like this.
  9. brightspark
    brightspark Member
    21,854
    yarm teeside
  10. Pete.
    Pete. Member
    6,196
    Kent, UK
    Siteblazer barrows. Never seen one punctured.
  11. KemppiFrog Member
    2,445
    Aquitaine
    The inflatable ones from our local B&Q are rated up to 200kg, but have plastic hubs with ss roller bearings for a 20mm axle.
    Any idea what thos yellow ones are rated at? Looking to make a dolly to piggy back a 500kg boat onto a larger road trailer. Wheels will be submerged in sea water on a regular basis, so either plain bearings or the ss rollers mentioned above. Rather fancy HD foam.
  12. http://www.rosscastors.co.uk/
    Ive had quite a lot of wheels and castors from these lot all seem to be good quality well worth a phone call and they'll find what you need
  13. gaz1
    gaz1 Member
    4,545
    westyorkshire
Advertisements
