gordon stephenson
- Skelton in Cleveland U.K.
Hope you chaps can help, Started using the welder and the pre programmed settings do not appear to be right.In manual mode I am having to set it to roughly twice the normal wire speed for 0..8mm wire,But in the auto synergic mode the wire is too fast and I have to trim it back on the adjuster by 20%.
So dived into the set parameters and this is what I found,Some of the codes I do not have a clue about,
P.CV synergic wire adjustment (set as per manual at 140)
P.Pr pre gas time set at 0.!
P.Po post gas time set at 0.5
P.H5 or P.HS function unknown set at 1
P.F1 " " set at 200
P.F2 " " set at 200
P.C1 " " set at 1
P.S1 " " set at 200
The machine has a pulse mode,
Does anybody know what these unknown functions are, If I had a clue I could probably figure out what they should be.
I don't know if these setting only refer to the synergic mode or affect all welding operations, The P.CV only adjusts wire speed ratio for synergic welding
Fingers crossed you clever folks can come up with some logical answers.
Thanks Gordon.
P.F1 " " set at 200
P.F2 " " set at 200
P.C1 " " set at 1
P.S1 " " set at 200
Thanks Gordon.
