Copper grease coats the material with a soft metal, namely copper.
Because it has not yet had ten years for the volatile parts to escape leaving behind the thicker fraction?seams copper grease is getting thinner though in my experience and does not last as long unless I need to try a different brand, my new tub just isn't as thick and copper rich as the old 10 year old tub
I guess that is quite possible I didn't think of thatBecause it has not yet had ten years for the volatile parts to escape leaving behind the thicker fraction?
Another happy user of copper grease here, can't recall not being able to undo anything later. Including glow plugs.
Think both SO & Facom do them, we use them for screws that have damaged heads especially where people have butchered Phillips with posi bits, the The nut plates usually have tight deformed thread (not seized)
http://www.specialityfasteners.in/index.php/self-locking-nuts-and-nut-plates
If the grease is removed completely, the remaining copper could cause the part to seize by generating unnecessary friction, akin to dust or muck in a joint.
had this with comma copperease. got a new tube of granville seems pretty goodseams copper grease is getting thinner though in my experience and does not last as long unless I need to try a different brand, my new tub just isn't as thick and copper rich as the old 10 year old tub
Mee, I wasn't aiming my post at you personally, but there are caveats to using copper grease I was trying to affirm to others reading the thread.
Others have had success, others failure, there's a grey area that would appear to be causing issues and I was trying to clarify a possible cause. That is, if the grease component is eliminated, or driven from the joint by heat/pressure, leaving the remaining copper behind it could cause more issues that help...
Having something copper "coated" in my mind/learning, implies an electrolytic/plated coating with respect to copper, this could be even worse as there would be an electric potential between the copper and the substrate, and/or the opposite face of the joint, accelerating corrosion of either the substrate or copper at the joint...
I've come to the end of my one and only can of Never-Seez, after 30 years of v.sparing use. It's been fantastic, but the price of it here is fantastic, too.I have to say I never use copperslip. Either neverseeze, it's fantastic and is fine in dissimilar metals or mastinox or equivalent. Although in a lot of applications neverseeze is the almost unbeatable.
I did watch a ut video, where they used a chemical to remove a broken stud in a ally head, but I cant remember what it was
Probably alum.
