Johnnybravo
- Northiam
CK WP9 flex head with the super flex lead, very nice light torch and will handle up to about 125amps for short runs.
Just don’t flex the head about too much. You will break it if you do.
The ck is 3/8bsp tail nut for a dinse adaptater.Also with ck does this have a 3/8BSP hose tail for gas and a dinse for juice - or is it a stripped tail an you fit a dinse?
I ask as the never show the other end of the torches..
Also if you got a binzel of similar spec would that have the extra flexy lead?
Also doe both have a jacket - or no?
Yep tgere is a power cable only and the gas goes up this. It aids a little for keeping the cable cool.so the gas and lecky goes up the 3/8 connrctor - ? if yes, the wire is like a tube?
Not sure about Fronius torches.i see
Im told my existing fronius torch (which is a bit of a thumper 220A air cooled) just has a 3/8 inside the dinse coupling head. So I could put a ck onto that.
Id probably get a cheap floor switch for the on off
The leather sheaths are even more supple than the nylon or denim ones if you get a good one. You’ll pay through the nose for it mind. Mines tectorch and they are pricey but very good.I felt like Superflex leads made a huge difference to manoeuvrability of the torch compared to the standard torch that came with my machine. The overbraid isn't the most heat resistant so maybe think about getting a cover on there. I went for a cheap denim one, more as a sacrificial cover, rather than a protective leather one which I was worried would reduce flex.
