Thanks guys - some good recommendations there, and it looks like @daleyd's going to sort me out so all good
For me the hacksaw has taken a bit of a back seat since they got their act together with quality thin discs, that said a cheap hacksaw blade is still to be avoided on the grounds of saftey. Nothing worse than have one explode into a thousand pieces when you lean on it slightly, to me thats worse than a bendy blunt one. As the above mentioned quality ones every time now.
Bob
put a dab of rocol cutting compound on your blade. blades last longer and it cuts a lot faster with no friction if your clumsy use bi metal blades if careful just use all hss ones
and smashing your hand against the vice when it doesFor me the hacksaw has taken a bit of a back seat since they got their act together with quality thin discs, that said a cheap hacksaw blade is still to be avoided on the grounds of saftey. Nothing worse than have one explode into a thousand pieces when you lean on it slightly, to me thats worse than a bendy blunt one. As the above mentioned quality ones every time now.
Bob
