Trying to program an Invertek VFD and having trouble getting the controls on the front panel active, by default they are not active and set up for external control.
Seems P12 in the program menu should be at 1 for them to work but with the wire between pin 1 and 2 it does not allow you to change them.
If you remove the wire pin it allows you to change them but once you replace the wire it reverts back to external controls...all a little confusing?
