Aluminium welding
  1. paul teggart Member
    12
    Dungannon, county Tyrone, Northern Ireland
    Hi guys, I wonder of someone can help me with a few enquiries.
    BACKGROUND: My employers are considering manufacturing rollers from aluminium. these are 12" pipe with 1/2" wall thickness and a 1/2" side plate to be welded inside each side of the pipe (fillet).
    I'm the one they're looking to as I've welded it in the past with a spool gun and TIG, both for a different employer.
    My questions would be as follows:
    1. Should we fabricate with MIG or TIG?
    2. What are the pros and cons of these in regards to aluminium?
    3. Which gas to use?
    4. Any other point?
    Many thanks in advance guys for any replies.
  2. HMB
    HMB Member
    1,283
    Essex near the Thames
    Mig it
    Lots of amps
    100% Argon
    Gets real hot quick
  3. HughF
    HughF Member
    4,080
    Corfe Castle/Frome
    Mig, He/Ar mixed gas if you can afford it...
  4. Richard.
    Richard. Member
    14,118
    Cambridgeshire
    If your employer is footing the bill a 400 amp pulsed mig with push pull torch system would be the ultimate solution
    Arclikeharrypotter likes this.
  5. Mee Banned
    1,453
    Here and There
    For production at speed then MIG every time.
    For high quality and finish then TIG.
  6. Kent
    Kent Member
    8,572
    Bowland, Lanacshire,UK
    Some of the modern 4 wheel drive feeds are pretty darn good. Not something I get into now so this is second hand info from guys that do.
  7. Rrunnach
    Rrunnach www.interventiontechnolog y.com
    969
    edinburgh
  8. Brad93
    Brad93 M J B Engineering
    3,107
    Essex
    I'd be getting a rotary table/turntable and a pulsed mig
    Richard. likes this.
  9. Kent
    Kent Member
    8,572
    Some big welds to lay 1/2 wall and 1/2" end plates. As production almost screams full automation if the quantity is there
    Richard. and Brad93 like this.
  10. Richard.
    Richard. Member
    14,118
    Cambridgeshire
    Could be a very simple rig too. Small rotator hooked up to the units start signal and a means of taking the torch out of the welders hand. Torch could be fixed so no need for spendy robot systems and magic eyes.
    Kent and Brad93 like this.
  11. Brad93
    3,107
    Essex
    Lorch turntable and pneumatic arm. That's what I'd have. You'd be looking at a few grand but if you had enough bits to make you'd make the money back
  12. Richard.
    Richard. Member
    14,118
    Cambridgeshire
    I wouldn't buy a lorch turntable. And if you have the welding set already it certainly wouldn't cost a few grand to automate that. A decent positioner/rotator and build your own way of holding the torch ridged in place. You could retract it with a manual operation slide.
    Kent likes this.
  13. Brad93
    3,107
    Essex
    How come rich?
  14. Richard.
    Richard. Member
    14,118
    Cambridgeshire
    Because for such a simple application it doesn't need pneumatics and a fancy digital lorch turn table. I wouldn't get any better productivity out of a £3k minimum system than I would out of a £1k system for that type of job. You can get a lovely rotator and make a retractable arm for the torch and get exactly the same results. You wouldn't even need to wire in for start and stop if you didn't want to do that. You could could kick it off manually in 4T and stop it the same way after 360°.
    Just my view. I used to fabricate a lot of parts and structures for automation welding equipment a while ago. Mainly cladding systems. This is as easy as it gets to make a nice system.
Advertisements
