yeah if you use it below 140 amps otherwise that one well defo blow a fuse as its 200 amp so its more powerfull then the other
Thanks for the advice guys! Really appreciate it.
if i were you i'd do quite a bit of reading about tig welding and what people have to say about different machines before spending any money
May I suggest something without taking offence, as you admit, you know nothing about voltages, have never welded and at the moment have a limited budget for the type of machine you really need, also planning to dive right into the sort of welding a lot of people struggle with even after welding with a mIG previously
Perhaps it would be a good idea to get some experience without rushing into things, a night class at the local tech, find someone local already doing similar and spend some time with them or similar.
I think it would give you a better understanding and help you decide the way to go and exactly what you need.
My suggestion is to avoid you rushing into something and finding you have spent a lot of money on something unsuitable.
It doesn't look as if it does AC TIG which you need for aluminium, nor would you expect it to for that price.
title says
SIP 05169 Weldmate P214 (200a)Ac/Dc Tig/MMA/Invert
