5 minute Chinese soup up for the job seeker's
  1. Proposition Joe
    Proposition Joe Member
    75
    Suffolk
    This could be useful for those running a chinese 63cc 850w generator.
    I bought one about 6 year's ago from b&q for £39, and it's had some heavy use running power tools such as angle grinders.
    Lately it's been a pig to start, but once running you can't argue with it. So i took the barrel off to give it a de-coke. It didn't need it, but i noticed a recess in the cylinder head near to the spark plug. I decided to fill this with epoxy steel & BANG she fired up better and ran the grinder stronger. Next up a romeu or nikon pipe and a stage 1 barrel tune Oh er i didn't take any pictures at the time, but will try to add one off the internet.
  2. CompoSimmonite Member
    3,462
    Werrington, Stoke-on-Trent
    I assume you have raised the compression ratio a little by filling the recess.
  3. the snooper
    the snooper getting older by the day
    19,715
    Hull UK
    Just hope the steel epoxy doesn't let go or you'll have bigger problems :D
    colnerov and Questions like this.
  4. Questions pre-moderated
    117
    Dublin Ireland
    Hard to beat an old lister, take a shim out, but at least she is purring again.
    Mee likes this.
  5. Cobbler
    Cobbler Codger bodger
    3,216
    Gloucestershire UK
    Reading Snoopers post about the epoxy,
    That went through my mind as well. I wouldn't have thought that would have made it start easier either, more likely the clean out & a bit of attention to set up maybe.
    the snooper likes this.
  6. Proposition Joe
    75
    Suffolk
    Ha yeah, good point there chap's. I did think of that AFTER i done it, but it's had a couple of hard hour's on it since i done it. But i will let you know of any catastrophic engine failures should that happen.
  7. Paul.
    Paul. Moderator Staff Member
    5,299
    Northampton. UK
    I have one of those cheap 2 stroke gennys, ideal for small tools and charging up the cordless batteries on site, its nearly killed me trying to start it from cold sometimes though , until I found the trick, on the last run of the day don't stop it using the switch, turn the petrol tap off and let it run till the carbs empty, then next time you use it give it a shake to mix the fuel up again before turning the tap back on,
    Mee and the snooper like this.
  8. knighty Member
    942
    Sunderland
    not sure about that exact model, but I used to use a petrol powered pump daily... after a couple of months it was always a pig to start but ran great
    took the center cover off the pull start... so you can see the nut in the middle... stuck a short extension bar in a battery drill with a socket on the end... used to fire up instantly with the drill spinning it over :-)
    Mee likes this.
  9. pdg
    pdg Member
    10,496
    Wiltshire
    You could do the same but using a mains drill running off the genny...
    :scared:
  10. KemppiFrog Member
    2,445
    Aquitaine
    Great idea.... But... I think you have just invented a perpetual motion system... So get it patented quick..:rolleyes:
    Mee likes this.
  11. jordan1 Member
    1,467
    Yorkshire England
    Sometimes there is a recess in a piston for a reason:whistle:
  12. Cobbler
    3,216
    Gloucestershire UK
    I was always told to do this on any 2 stroke, if you leave the carb full, the petrol starts to evaporate, leaving an oil rich mixture which won't go easily through the jets. When I used to mess about in boats, I always did this with the outboards & never had a problem starting them. Others I knew didn't do it & sometimes they struggled to start up.
    Mee likes this.
  13. the snooper
    19,715
    Hull UK
    It's also good to do it with 4 stroke engines so the carb is empty then the petrol won't go off and block the jets
    dobbslc likes this.
Advertisements
