this was made a while back after being told by the bead blaster i need to scrape all the seam sealer and underseal off before blasting and didn`t really relish the thought or lying underneath while doing it...
the main bits are 80x80x8mm box section link bar is 50x50x3 pivot pins are 40mm dia solid bar and the rotating sections that fit onto shell are 60x40x3..
the MIG welding was carried out by "thirdtimeluckyfabricator" as quite frankly i bleedin hate mig welding...
to make it easier to lock it off at various rotation pints i drew up a disc on cad and had it laser cut out of 10mm steel..
not shown in the pic but now added is a bar with 2 rose joints 1 on the min upright 1 that bolts to the disc...
if only it made scraping french tin easier......
spinning the shell round no problem paint the underneath, fit axle then like a pratt holding with one hand pulled the pin, weight came over center, hand now attached to sharp object!! weight keeps rolling till it cut the palm of hand into a nice flap, could see the nerves & ligaments for 3 fingers & as I said 30+ stitches & 2 month till I could use hand, Another half mm. deeper a it would have been serious surgery on nerves & ligaments.
