im looking to weld some adapters into a radius arm for the rear suspension of a car.
Setup showed here:
The arm itself is made of tubing 3mm thick, the threaded adapters are 6mm thick, im wondering if my clarke 150 will be able to achieve full penetration?
As a rear suspension component on a rear wheel drive car it is a critical component and i want to make sure it will do.
The metal arm is now cleaned up and now has the same polished finish as the adapter.
Also anyone suggest settings
Setup showed here:
