So I have been after a compressor for a while thinking it would be a handy thing to have a around when working on my vw beetle.
I found won on ebay and won it at what I thought was a great deal. Went to collect it from the guy and he seemed genuine and he worked as an industrial compressor (refridgeration etc) engineer. He said he had recently serviced the compressor and fitted a new motor.
I have not had much chance to use it since I collected it as my wife has been working weekends and I have had to look after my son.
So tonight I started it up to see what the deal was and it doesn't seem to be working correct.
When I turn it on the motor starts and the tank starts filling up then after a couple of minutes it just dumps the air out through the pipes near the switch. I don't have any instructions or any tools to test it with, all I have is a lenght of hose and a paint gun.
It's an Air Master 15/50 and I can't find much info on the net about it.
Anyone have any idea what I need to do to get it setup properly.
Here are all the details from the little plaques on the side:
AirMaster Compressor
Model: Popular 15/50
M.W.P. : 150 psi
OIL: SAE30
Clarke Motor
Type: 9OLB/2
V: 230
HP: 3.0
KW: 2.2
Hz: 50
RPM: 2700
PH: 1
A: 14.5 (probably shouldn't be running it off a 13amp socket?)
Switch: 12bar, 175 psi
Help?
Here are some photos so you get the idea:
M.W.P. : 150 psi
OIL: SAE30
Clarke Motor
Type: 9OLB/2
V: 230
HP: 3.0
KW: 2.2
Hz: 50
RPM: 2700
PH: 1
Help?
