I'm pleased with my attempts so far at using my £19 Wolf arc welder to fill in holes in car body thickness steel sheet. I'm using 1.6mm 6013 rods and have only a few minutes experience so this can't be very difficult. If I can do it, anyone can. The only special step I took was to flatten out a bit of 22mm copper pipe and put that behind the sheet. It serves to conduct away heat and, with the work horizontal, it means any puddle of molten metal can't really go anywhere, so it must reduce the chance of blowing holes. I like the fine control I appear to get with the tip of the arc rod. Slag is a non-issue. It just come away. The welds are far from perfect and might not pass any British Standards but the end result is good enough for my needs. Here's the first hole I plugged by cutting out a small rectangle of steel, then I filed it down to an oblong, to fit the hole:
Then I tack welded it and decided that was all I needed:
Next I cut and filed down a circular bit of metal to fill a hole. I tried to sort of seam weld this and nearly succeeded. But at '9 o'clock' I blew a small hole, which I subsequently filled (no problem). Also, there's a shortfall around '11 o'clock, but overall it's strong enough for my needs. Perhaps the hole resulted from the copper not being right up to the steel at that point.
Here's the reverse. If anything, there is insuffient penetration, rather than too many holes, but that's the least of my worries:
Finally, here's a hole which I plugged entirely with the steel from the arc rod, rather than by using a plate. This, and the earlier weld have been filed down a bit but never were very proud of the surface:
I also have a MIG welder but I hope I won't need it. The cost of gas and the much larger storage size of the MIG welder put me off, together with the likelihood of wire feed issues. I will press on with the arc welder before I even try out the MIG welder. Arc welding strikes me as cheap to buy, cheap to run and dead simple.
funny, snowcat!
