Go Back   MIG Welding Forum > Welding Techniques > Other Types of Welding
Reply
  #1
Old 26-03-2008, 4:50 PM
amron
Default Spot Welding Electrodes
Hi
does anybody knows what kind of kind of material (I know it"s some sort of copper ) the electrodes of a spot welding machine are made of? I would like to know the material"s no. as per some standard.
Thanks
Amron
  #2
Old 26-03-2008, 7:11 PM
Robotstar5's Avatar
Robotstar5
Casanunda
Try contacting :
www.welserv.co.uk or
www.bfentron.co.uk
I'm sure one of them should be able to help you
__________________
Finest Swordsman, Outrageous Liar,
Own step ladder provided
  #3
Old 31-03-2008, 3:29 PM
supinder
Default spot welding electrodes
Normally 99.9% copper is used for spot welding, but for large scale production chromium zirconium copper is used ( Cu-Cr-Zr). It has more hardness (83B rockwell) and much higher annealing temperature around 500 degree centigrade as compared to pure cooper which is 200 degree centigrade. For current detail of different capacity spot welders follow: http://www.sohalwelding.com/06-weldi...t-welders.html
  #4
Old 01-04-2008, 12:31 AM
GeorgeB
Senior Member
Does anyone know why shielding gas nor any kind of flux is required for spot welding?
  #5
Old 01-04-2008, 10:15 AM
English Steve's Avatar
English Steve
Senior Bumpkin
Spot welding is 'resistance welding'. The two pieces of metal are clamped together between the electrodes, and a current is passed through them. The resistance caused at the join causes the metal to heat up to a welding temperature and the clamping pressure of the electrodes helps the metal to fuse locally. The outer surfaces of the metal remain relatively cool due to the heat dissipation into the electrodes (which on industrial units are usually water cooled), usually reaching a 'plastic' condition resulting in slight indentations on the surface caused by the clamping pressure of the electrodes.
There is no arc or flame present and as such you are not actually burning anything, therefore no oxidation and no need for flux or shielding gas. The metal needs to be very clean to give a good contact and good results.
I am sure someone will be able to give a more in-depth explanation.
Regards
Steve
  #6
Old 04-04-2008, 2:36 PM
GeorgeB
Senior Member
Quote:
I'm not sure they need to, thanks, because your explanation strikes me as excellent. My understanding is still partial however as to when exactly shielding gas or flux is needed and when it may not be required for welding type work. I mean shielding gas isn't used in steel or aluminium works, for example, when molten metal is being poured from a furnace into moulds. I would have expected the metal to get oxidised and spoiled whilst being poured. Is it just the presence of an arc which lead to oxidation? And if there's no arc, there's no oxidation?
  #7
Old 04-04-2008, 4:10 PM
English Steve
Senior Bumpkin
Hi George.
This is stretching my knowledge a bit, but here goes...
When melting iron in a cupola for casting etc, flux is added in the form of limestone to remove non-metallic impurities. These impurities then float to the top of the molten iron and form a slag cap which effectively prevents air coming into contact with the iron. Periodically the slag is tapped off. The molten iron is always removed from the bottom of the cupola as this is where the 'cleanest' material lies.
The molten iron is then often treated by adjusting the temperature and adding calcium carbide or similar desulphurising agent. Magnesium treatment is also carried out if SG iron is required. Finally, the iron is innoculated by adding a mixture based on ferro silicon immediately before the pour.
With molten steel, basic slags are used to control the levels of phosphorous and sulphur, and the steel is 'boiled' by injecting oxigen into the molten bath which removes unwanted disolved gasses. In some steelworks Argon Oxigen Decarburisation (AOD) is practiced in treating stainless and low alloy steels.
By the above methods, most unwanted impurities are removed before the pour, and the pour itself (if done properly ie smoothly) will not pick up any further impurities from the surrounding atmosphere.
When electric welding, the transfer of metal from electrode to workpiece is quite violent and results in the entrapment of impurities from the surrounding atmosphere and the workpiece. Thus either a shielding gas is required to keep the atmosphere inert, or a flux is used to form a slag to remove the impurities from the weld pool. Oxy Acetylene welding is less violent so you can generally get away with not using a flux or shielding gas.
Re-reading the welding bit above it doesn't sound quite right, but you get the general idea. Again, someone on here will be able to give a better explanation of the welding requirements for shielding gas and flux.
Steve
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
spot welding with a 230TEC Saff Clarke 5 23-01-2008 7:12 PM
Spot welding help.. robbie S Other Types of Welding 5 23-12-2007 6:01 AM
spot welding classic2cv Welders and Welding Machines 2 14-05-2007 9:10 PM
Spot welding - with a TIG? malcolm TIG Welding 2 25-07-2006 10:52 AM
MIG 'spot' welding happy jack MIG Welding 1 05-12-2005 2:56 PM
Powered by vBulletin® Version 4.0.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
