Go Back   MIG Welding Forum > Welders and Equipment > Welders and Welding Machines > Migatronic
Reply
  #1
Old 29-01-2008, 9:47 AM
astro_al
Rocket Scientist
Question Mig WFU interconnect.
Hi guys, I'd like to make up a new interconnection 'cable' (bundle) between the base-unit (transformer) and wire feed unit on my Migatronic Dynamig 405. The current one is very short.
It contains a gas hose, main current carrying cable and wires for control (trigger input etc) with an amphenol plug on each end.
Q's:
1. Anyone know where I can lay my hands on some of the outer sheath stuff that contains the various cables/hoses?
2. Anyone know what type of wire is good for the control wires, hardy enough to withstand abuse?
3. Anyone suggest a new socket/plug, the ones I have are cross-threaded
Any other inputs gratefully received. Cheers, Al.
  #2
Old 29-01-2008, 9:55 AM
Robotstar5's Avatar
Robotstar5
Casanunda
Amphenol or "MIL" spec plugs / sockets available from RS components, look at the mating plastic face for a number eg. 7P or 14S to specify the correct types.
Try IGUS chainflex or LAPP olflex classic for the cable
Hope this helps, Stuart.
__________________
Finest Swordsman, Outrageous Liar,
Own step ladder provided
  #3
Old 07-05-2009, 7:48 PM
Welsupplies.co.uk
Banned
You need a run of gas hose, power cable 70mm2 and a length of multicore cable. Then pull them through the sheath yourself.
What plugs and sockets have you got now? Maybe i can match one up for you, saves confusion when re soldering the pins..
Any multicore cable is good if your having it in a sheath, I tend to use 1mm2 (cant go wrong)
And for the sheath i use 4inch hose that farmers use for their big sprinklers, (quite cheap and very heavy duty.
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sealey Mig Welders Turbo Sealey & Siegen 10 01-04-2009 12:20 AM
Best Way To Mig 18ga. SHEET METAL TOGETHER SCHOONER Learning MIG Welding 20 05-01-2009 4:03 PM
Mig, Tig, Or Maybe Gas,,,,,,,,,,,,, JWPATE MIG Welding 14 31-01-2008 2:04 AM
Just bought a Mig welder.. Just broke my Mig welder. Hi there! gordo Introductions 7 18-01-2008 6:02 AM
Mig brazing; necessary? WindWalker MIG Welding 15 22-03-2007 12:20 AM
Powered by vBulletin® Version 4.0.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
