Go Back   MIG Welding Forum > General Forums > The Brew Room
Reply
  #1
Unread 20-11-2007, 1:53 PM
druist
Default Electricity Usage
Is there an equation or does anyone have a rough idea of how much a 135w mig welder would use in terms of KW/h for say 5mins use?
I am trying to estimate the cost of using a DIY mig welder at home. Just curious if anyone has anyone tried to do this calculation?
thanks
drew
  #2
Unread 20-11-2007, 2:00 PM
peterd51's Avatar
peterd51
happy to be here!
Hi,
it's a 'hobby' I use it and ****** to the cost! :-)
I'd say it'll run at a few pence an hour though I've never really checked.
Regards
Peter
  #3
Unread 20-11-2007, 2:10 PM
irondarren
Senior Member
I run (well did) a 250amp machine which spent most of its time set at 220-230amps, used daily in the fabrication of gates, at that sort of power output its drawing about 6kw, which would mean at the current cost of electricity (about 10pence per KWh) in an hour would cost 60 pence, but it never runs for a full hour. I recon it probaly costs about £5 a week to power it.
In the Lorch book of welding there is an interesting bit about what does 1mtr of welding cost. If lorch's figures are correct and i have no reason to doubt them. they claim 76% is the cost of the labour, 9% is the cost of the gas, 4% is the cost of the electric, 6% is the cost of the wire, and 5% is the cost of the welding unit.
So in reality if everytime you replace a roll of wire (i assume you use the baby rolls) and it cost you £10 i would guess you have used no more than £5 worth of electricity.
Does that help?
  #4
Unread 20-11-2007, 6:09 PM
piman
Senior Member
Hello Drew,
the equation is 135/1000 x 1Hr Kwh. However as you welding current varies so does the load, i.e. 135watts will often be much less. How much will need a meter to measure your current drawn from the mains. Wattage is volts x amps x power factor (Usually around 0.8)
Not easy to know without some test equipment
Alec
  #5
Unread 21-11-2007, 2:31 AM
greyshirtguy's Avatar
greyshirtguy
Persistent Learner
Default Cost Estimation
hmmm I have wondered about that too - it's probably too hard to guess how all the variables will come out without actually measuring (I even had a few fleeting ideas of current meters etc - yer, I'm a nerd)
Although, I'd say the cost of the electricity is quite small (as IronDarren pointed out 4%)...
Consider these two points:
1. Calculate the max your welder could possibly use and know that it's typical usage will be less than that.
Take your supply voltage and multiply by the Max current your circuit (fuse/breaker) can supply to your welder. That should tell you the maximum possible power it can use. Decide how many hours you use your welder for and multiply out to get your total energy usage. Multiply by your current electricity tarrif rate.
eg. Mine is supply is 240V, through a 16amp breaker
240x16 = 3.84KW
My Tarrif is apporx 15c per KWh...
So if my welder max's out my circuit it could use up to 57.6cents per hour.
2. If you really want to get an idea of how much power each setting uses you could......take some "before" and "after" readings from your power meter, and note the number of KWs used during test welds at given settings, wire speed/size.
Hmmm, actually This might not be a very smart option at all !!!! - since it seems that would take at least 1 hour of continous welding for my meter to read an extra 3.84KWh's...hmmm My meter also has a "spinning wheel" that would indicate much smaller amounts of consumed power - but you'd have to count the revs....wonder what the wife would say?
__________________
Daniel
Experience: that most brutal of teachers. But you learn, my God do you learn.
  #6
Unread 21-11-2007, 8:04 AM
peterd51's Avatar
peterd51
happy to be here!
Hi,
yes, especially when you insist on turning off all other electrical items while testing...
Regards
Peter
  #7
Unread 21-11-2007, 8:07 AM
Drains's Avatar
Drains
Good as gold!
I'm not convinced thats Drew's welder is 135 watts. You'll not do much welding at that. Did you mean amps Drew?
Greyshirtguy explains it all nicely.
  #8
Unread 21-11-2007, 1:01 PM
piman
Senior Member
Hello GSG,
you haven't quite got it right. The breaker current merely gives the maximum available current, what you need is the draw from the welder which is variable. Also you need to consider the power factor in your calculation, volts times amps is not watts with A.C. (it is with D.C. normally)
Simon,
yes, 135 watts is quite light, maybe it is the output current as you say, but certainly not input current.
Alec
  #9
Unread 21-11-2007, 2:23 PM
peterd51's Avatar
peterd51
happy to be here!
Hi,
I think the 1st line of GSG's item 1 covered it...
'Calculate the max your welder could possibly use and know that it's typical usage will be less than that'
A few pence an hour is the maximum...for DIY use it'll be a few pence a day in actual use.
Regards
Peter
  #10
Unread 21-11-2007, 6:17 PM
Towing and trailers's Avatar
Towing and trailers
Hi
135w is 0.135kw to start off with. this is very low and I have a bigger soldering iron.
this will run a few cooling fans but will not melt metal.
you probably mean 135A as this is a bobby welder
the wattage you are using is calculated volts x Amps = Watts
1000 watts = 1KW
and costs depending on supplyer 7p per hr.
the voltage you are using should be on the plate near the the power lead and this is known as an open circuit voltage probably about 28v if it is 135A you are not going you are going to struggle running the power flat out so you may manage 125A as this is dependant on wire dia and speed and cheaper sets strugle to give the power they say.
28V x 125A = 3500W = 3.5kW this is if you are pushing your set at full power with a good ark.
if you are fabricating you are welding a max of 5% of the time.
if you are doing production fabrications you are welding maximum 25% of the time.
if you are plating you are Welding a max of 40% of the time and your set will be dead after about 200hrs as it is not made for this.
so if you are fabricating like I would expect there is a maximum of 5% of the time welding more realistically 2.5% as you are not doing it proffesionally.
3.5kw x .025 gives you 0.0875 kW at a cost of 7p ish a kw meaning it will cost you .6125p per hr.
I have you an important question how many lights do you have because these will cost more.
the lights in my old workshop used to use approx 8kw and this was the most expensive electricity cost on the workshop.
yes a welder will make your elecrtic meter go dizzy but only whist it is running. but so will your kettle as this uses about the same power and runns about the same length of time.
dont bother aboth the power you welder uses.
Pete
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
american tig welders british electricity h0tr0dder_uk TIG Welding 3 02-05-2007 8:29 AM
Powered by vBulletin® Version 4.1.12
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
