Having read on here that Lechler epoxy primer doesn't contain isocyanates, I was a little alarmed to find when I had some delivered that the label says it does. I emailed paints4u and they admit they've put the label on themselves as a general safety warning. It doesn't however actually contain isocyanates. Make of that as you will.
My question here is what preparation is needed before spraying. I aim to sand and grind the metal as rust free as possible, but I know that at the microscopic level it will be still be full of gigantic gouges of oxide. Is it better to try and treat this with a phosphating product such as Metal Ready, then epoxy this, or just spray the cleaned up metal?
before applying paint, the reason i did the test was because i have sandblasted some panels which i could not paint the same day, so immediately after blasting i just sprayed some metal ready on to stop any rust forming,, the parts are still in bare metal now after 6 months! but still have zero rust on them(metal ready is good). I wanted to find out if i could just wash the sandblasted panels down with panel wipe(not water) and then epoxy prime them, as washing with water would cause them to rust again! i sprayed the test parts about 5 months ago and they are still good, no lifting on the paint,etc... so from now on i will probably use metal ready on all panels i take to bare metal because for one it means you can let the panel sit in bare metal without rusting and two it makes the paint stick better
I think the trick is if your not washing it down with water before painting, make sure you clean thoroughly with panel wipe before painting, get one of those pressure spray bottles to spray the panel wipe on.
