Will_Davis
Ok, Lets stop the funny comments straight away!. I'm 6' 3" so when I snuff it I will need 6' 6" of shroud wrap!!
Seriously though my TIG has been supplied with 3 different shrouds: Nos: 5,6,7
These numbers seem to be unrelated to actual diameter ( but thats not a problem )
How do I know which size to use? The tutorial mentions "For general purpose work on steel a number 7 shroud is a good compromise. A smaller number 4 shroud would be more suitable for fillet welds, and larger shrouds might be used for aluminium. As a rule the larger the shroud the better the gas coverage."
I am concentrating on butt welds in 1.2mm or thinner SS sheet.
I assume that the bigger the shroud the more gas is needed ( More gass = More Money per mm of weld
As an overall request is there a one-off "covers-all" table of Tig specs:
Material / Weld Orientation / Thickness / Tungsten dia / Filler Rod dia / Current / Shroud dia / Gas Flow / 'Owt else I've forgotten!
Cheers
Will
)As an overall request is there a one-off "covers-all" table of Tig specs:
Cheers
Will
