pondy
- chedburgh, suffolk. uk
adding another cooling fan into my clarke 150en turbo mig. im adding a euro wire feed motor, my pcb has the power to drive it but the heatsink for the power transistor that drives the motor will just run hotter, so i want to add a small fan just behind the pcb.
this is the motor im adding. have used this guy before and he is very helpfull. the motor is not going to bolt into the welder easy. i need to cut away into the centre plate to get the wire feed more central to the wire reel. but after the welder should be great. the motor does not have enough torque on the lower wire speed settings and judders alot making a bad weld.
http://www.ebay.co.uk/itm/MIG-WELDE...378?pt=LH_DefaultDomain_3&hash=item1c2b7f1a4a
i can find alot of small computer fans but they are all 12v, dont know if there is a 12v feed inside a welder?
this is the best i can find, and its still slightly to large
http://www.ebay.co.uk/itm/80mm-3-23...pt=UK_Computing_Case_Fans&hash=item2c68005b16
any ideas?
any ideas?
