peterd51
happy to be here!
Hi Guys,
there's been a number of these sold recently on ebay, at least two a day and around 26 in total so far. Prices range between £150 and £260 with another £20 delivery, I got mine for £186 and it was delivered yesterday (took a full week to get here).
The company are in Germany and the manual (written in German unfortunately!) states 'CE' on the front cover. I can make out some of the instructions...
max cut to 12mm
20 - 40A output
230v single phase input
4.7KVA input
96V out
work cycle 60%
HF oscillator ? (starting up?)
4.5 bar 120 ltr/min
weight 9 kg.
It's relatively easy to set up, plug the various things into the relevant socket, but does anyone know what the 2.5s and 5.0s refer to please?
the torch looks fairly standard although to TBH I've not had much experience with these things. The lead and air-line are 5 metres long whch is pretty good, but the earth lead is only 2 metres. The earth lead has a decent clamp though. Also the torch has a nice blue zip-up bag to give it some pretection if travelling.
there's a regulator with a plastic/perspex bowl at the bottom, I assume to let water out? and this sits in an 'L' shaped bracket that I welded onto a market stall clamp so I could move it around if I need to. In the photo I've lifted the regulator slightly so you can see the bracket/clamp, it normally sits vertical.
There are a couple of connectors and jubilee clips supplied but I decided to keep the air-lines short-ish on the unit so I could move it around easier and I'll use an extension line from the compressor.
Obviously there's a slight leak-off on the push-fit connector but that's on the 'line' side of the regulator so it shouldn't be a problem. I needed a couple of extra jubilee clips and a connector.
So I found this bit of 5mm plate and set the unit to 2.5s, 20Amps, 2 bar (about 30psi?) and made my first cut, the middle one in the photo, not very pretty!
I upped the current to 25A and made the cut on the right, getting better.
The last attempt, on the left, was at 30A and looks pretty good with the cut going all the way through except for a couple of spots about 5mm long where I probably jerked my hand forward slightly.
Obviously I need to practice a lot more so I'll have another go over the next few days with other adjustments...more air/amps, use the '5.0s' setting and also with different thicknesses of metal.
So far it's impressive. It's very quiet in use! Build quality is OK (considering the price!) the only dodgy things I noticed was a slight 'ding' in the torch power connector on the front cover, but the connector fastens up OK, and a couple of paint runs/bubbles.
I'm hoping that it can use 'standard' consumables...
I assume the ceramic cup can get damaged and the electrodes will need replacing eventually.
Can anyone else suggest what will need replacing with wear?
Does anyone know where I can see a diagram of a cutting torch so I can reference these parts?
Also, can anyone give me any advice on using a plasma cutter please, ie, rough estimate of amps, air, 2.5s / 5.0s, etc, for metal thicknesses of, say, 3mm, 6mm, 9mm & 12mm? I can then work out the rest as I go along.
Regards
Peter
max cut to 12mm
20 - 40A output
4.7KVA input
96V out
work cycle 60%
4.5 bar 120 ltr/min
weight 9 kg.
Regards
Peter
I think it's just the german equivalent of tig but I'm not too sure. Can't think what a wig welder would look like. Glue gun???
