D DuffyBB Member Messages 265 Jan 7, 2012 #1 Will these be any good for using while welding/grinding etc?...linky
J justin Member Messages 222 Jan 7, 2012 #2 never used those but anything has to be better than nothing as for welding if you don't thing your ventilation is good enough don't do it
Shedendman Member Messages 5,201 Jan 7, 2012 #3 Used that type before for dusty conditions,they're quite good,as for welding fumes i cant say.
brightspark Member Messages 39,252 Location yarm stockton on tees Jan 7, 2012 #4 its a dust mask .ok for grinding wont be much use for fumes.
Sub-arc Member Messages 250 Jan 7, 2012 #5 Only 4 disposable for welding in the 3M range. Pt #'s 3M9925,9928,9922,9926 If you google above you should find a supplier near you. I'm sure others make equivs of those. Not cheap either.
