Go Back   MIG Welding Forum > Welders and Equipment > Welders and Welding Machines > SIP & Cosmo
Reply
  #1
Old 22-08-2007, 7:23 PM
locostollie
Default How Much Power
I need a genny to power a sip cosmo 130 but not sure what power it needs.
All the book says is that it needs to be wired via a 16A cct bkr so by my crude calculation
Power = Amps x Volts, so power = 16A(max) x 240
Power = 3840w => 3.8Kva???
There is no power rating to be found in the booklet that came with the welder so should I look for around a 4kva?
  #2
Old 22-08-2007, 7:33 PM
irondarren
Senior Member
First things first a 6kva generator produces 4800w, basically KVA x 0.8 = KW (if i remember correctly). You have to remember that there is a surge when you begin welding so your generator must be able to cope with this. In reality you are looking at a gen similar to this size http://www.machinemart.co.uk/shop/pr...iven-generator which unfortunatly is going to cost a lot of money. If you try using a smaller generator (might get away with slightly smaller), the only thing you will weld up is the alternator on the generator
Diywelding sells welder gensets, not sure if he can do a deal on a plain generator, or possibly weldequip might have his sources for cheap good quality gen units
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
power output irondarren Tools, Materials and Techniques 10 15-07-2007 7:08 PM
how to build a mig welder power supply? amron Welders and Welding Machines 13 02-05-2007 10:18 PM
Power settings and Penetration? letchy Learning MIG Welding 2 16-02-2007 8:46 PM
COSMO 170-SIP Migmate 150 Power settings?? PaulT SIP & Cosmo 5 26-01-2007 5:46 PM
MIG welder power supply design panelstitcher Welders and Welding Machines 5 10-06-2006 10:54 AM
Powered by vBulletin® Version 4.0.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
