Sorry about this but my posts seem to be longer thany anyone elses.
Anyway, I was trying to flog my Sip Migmate Pro 170 to a mate last night. When he asked "does dual purpose mean it can do stick as well as mig"?
It suddenly dawned on me that if I modified the machine by puting a dp/dt switch on the thing to permanently switch on the trigger and switch off the wire feed you could use the +ve & -ve terminals on the front for stick arc welding.
We tried this by hooking up arc cables to the terminals, loosened the wire feed roller and jamming the torch trigger on and on full power it happily stick welded 5mm plate.
Thousands of welders must have tried this before now, but does anyone know what the consequenses might be? Can a 170amp mig transformer & rectifier designed to melt 0.8mm wire withstand melting 3mm rods?
Any advice would be appreciated as I don't want to do this mod only to find that after ½ an hours welding the machine is completely burnt out.
