vince_team
Hello,
I'm from the perspective of purchasing a mig post in some time.
I would like your opinion on it:
(the price of this item is approximately 330 € to bid + shipping and immediate purchase of 430 € without shipping)
Here, thank you for your help
Vincent
The microprocessor controlled MIG MIG professionals TIGMIG SYNERGIC-205 welding protection equipment designed for industrial applications. With the powerful and compact device can be up 15kg/300mm coil diameter and wire gauges used by 0.8-1.0 mm.
The device is ideal for MIG / MAG with or without gas (son cored) and MMA welding (MMA) The IGBT inverter, the core of the device that produces pure DC - The mark has the advantage of low and flatter the weld is on the material.
This creates a virtual welding splash is possible. Also problematic joints such as falling, standing, or over-head are made so easily. There may be parameters such as wire feeders, welding current and ARC-Force steplessly regulated. The digital display, you have the amperage volts or more at a glance.
Vincent
