rtbcomp
Moderator
- Sheffield UK
This is an uprated funnel for filling the "Ebay" blast pots.
Ingredients:
Small propane &c gas bottle
1-1/4 BSP male (OD) reducing bush
1-1/4 BSP Female/Female lever operated ball valve
This is what you do:
Prepare the bottle by purging and remove the valve
Cut the bottom off the bottle
Weld the bush to the top of the bottle over the hole
Enlarge the hole using a holesaw guided by the bush
Fix the valve to the pot using PTFE tape and position the handle facing the operator and so that the handle goes down to open the valve
Trim the handle so the valve will open fully
Screw the funnel into the top of the valve
It would be useful if you have done this mod
http://www.mig-welding.co.uk/forum/showthread.php?t=8921
so the valve can be opened to let air out as the grit flows in
Make sure the grit valve is clear of grit before operating to reduce wear.
Ingredients:
