Go Back   MIG Welding Forum > Tools, Compressors and Metal Coatings > Tools, Materials and Techniques
Reply
  #1
Unread 13-11-2009, 4:25 PM
Bigjoe
Bored!
Default Startrite Mercury pillar drill.
Afternoon all,
Well ive finally managed to get 5 mins to go and collect the Startrite mercury drill i won on ebay about 4 months ago (from RBeadle on here) it needs a little tlc and im waiting for a 3 phase inverter to arrive (ebay £26) but it needs a chuck key,i think its a mt2 chuck,so are they industry standard keys or all different?
Joe
__________________
I am merely a man amongst giants.
  #2
Unread 13-11-2009, 6:03 PM
Endacy's Avatar
Endacy
Senior Member
I had the same dilemna when I needed one (and now I need another, for a 16mm MT2 chuck!) so I took the chuck to my local Cromwell Tools and asked them to supply me one that fitted, that way I knew it was right. I got a good make one for about £4.
Of course that only works if you have a tool supplier nearby. I am lucky and have several.
  #3
Unread 13-11-2009, 6:16 PM
TIG Paul's Avatar
TIG Paul
Moderator
Most pillar drills will use a K3 key, K2 is for 1/2" pistol drill chucks, and K0 for the small 3/8" pistol drill chucks.
__________________
Paul.
  #4
Unread 13-11-2009, 6:41 PM
Drains's Avatar
Drains
Good as gold!
If you're in Embra at all Joe, drop into Wilkinsons (Arthur St, back of Pilrig St and Leith Walk) - ideally with the chuck, and they'll sort you out. Alternatively if you're feeling rich, get a new quick release chuck from Cromwell or J and L. Make sure of course its an MT, not Jacobs taper, although you can get chucks for either.
  #5
Unread 13-11-2009, 9:06 PM
Bigjoe
Bored!
Thanks chaps,i might try wilkinsons one day Si, ill check the numbers on the chuck tomorrow but im pretty sure its a 16mm MT2 (and its got 10 speeds woohoo!)...will probably only use 2 of them tho! )
__________________
  #6
Unread 13-11-2009, 10:27 PM
RedOrZed
Senior Member
Quote:
I second this, a QR chuck is worth it's weight in glod.
If you find a cheap chuck on fleabay with no arbor, I've got some JT to MT2 arbors at the back of a drawer - Cromwell were flogging them cheap so I bought some
  #7
Unread 16-11-2009, 8:13 AM
JimM's Avatar
JimM
Senior Member
Sounds like I've got the same drill (high/low lever on the quill ?) It's definitely a MT2 taper. Go for a QR chuck - I got an Albrecht off Ebay for £20, it's makes life so much easier
If you need an arbor and haven't got a engineering place local then have a look at http://www.chronos.ltd.uk/
  #8
Unread 16-11-2009, 8:25 AM
Bigjoe
Bored!
Thanks Jim,
I might have a look on the bay, i was trying to work out what the lever on the side was,mine says 'On & Off@ at 90deg to each other,is this right?
Joe
__________________
  #9
Unread 16-11-2009, 8:32 AM
astro_al
Rocket Scientist
Could be, I have a meddings drill with a rotary switch which just alternates on-off-on-off as you turn it. This way when 'on' no matter which way you turn the switch it will move to 'off' - probably a safety feature?
Al.
  #10
Unread 16-11-2009, 8:38 AM
Bigjoe
Bored!
That sounds like it Astro al, Mine is a shaft that sticks out that someone has welded a bit of bar onto,infact its missing quite a few knobs etc, (must have a knob thief)
Ive found a business card from a firm called team rewinds that did some work on it,so ive emailed them to ask if they know any history,it looks like a fairly new motor (375w) on it.
__________________
Reply
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
Using a pillar drill paul_f Tools, Materials and Techniques 40 28-09-2012 3:36 AM
Pillar drill mini nige Tools, Materials and Techniques 13 05-03-2009 7:37 PM
Clarke Pillar drill dwdw Tools, Materials and Techniques 5 27-02-2009 7:43 AM
Powered by vBulletin® Version 4.1.12
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
