i am currently in the process of making a manifold to fit zzr600 bike carbs on a vauxhall 1.6 8 valve :d
regards dan
im wondering why you would want to do that the zzr carbs each feed a 150cc cylinder where as the 1.6 engine is 400cc per cylinder.
so will the zzr carbs be able to supply enough air/petrol to each cylinder the venturi may restrict air flow as its not designed for a 400 cc cylinder.
I am currently in the process of making a manifold to fit zzr600 bike carbs on a vauxhall 1.6 8 valve :d
regards dan
Why on earth fit carbs at all? Horrible things!
Omex is an expensive way of doing things. Megasquirt is diy tunable, cheaper, and versatile.
